跳转到主内容
加入维修社区 - 创建账户
Xbox Wireless Headset Microphone Replacement
你所需要的
  1. Xbox Wireless Headset Microphone Replacement, Headset Microphone: 步骤 1 中的图像 1,2 Xbox Wireless Headset Microphone Replacement, Headset Microphone: 步骤 1 中的图像 2,2
    • Remove the left ear pad from the headset. On this type ear pad you can grasp the pad itself and pull away from the center, then lift it slightly, this disengages the soft, flexible plastic of the pad from the rigid plastic it is held under that keeps it in place.
    • The pad may then pull off easily, or you may need to hold it with the thumb and forefinger of your other hand to keep it from slipping back into place while, moving an inch or so away from where you are holding it you repeat the action of pulling it outward and lifting one or more times until it is freed.
    • As an analogy; until a photo can be added for clarification, think of it like a button. The 'button' is the part of the earphone we are removing the pad from. The back of the ear-pad has a 'button-hole' held under the 'button' like your shirt. It's elastic enough that we can pull it like this to 'unbutton' it.
  2. Xbox Wireless Headset Microphone Replacement: 步骤 2 中的图像 1,3 Xbox Wireless Headset Microphone Replacement: 步骤 2 中的图像 2,3 Xbox Wireless Headset Microphone Replacement: 步骤 2 中的图像 3,3
    • Remove all screws with your Phillips 0 and Phillips 00. There are 16 screws altogether red circles and two in the red rectangle
  3. Xbox Wireless Headset Microphone Replacement: 步骤 3 中的图像 1,1
    • Carefully ease out the circuit board and microphone.
  4. Xbox Wireless Headset Microphone Replacement: 步骤 4 中的图像 1,3 Xbox Wireless Headset Microphone Replacement: 步骤 4 中的图像 2,3 Xbox Wireless Headset Microphone Replacement: 步骤 4 中的图像 3,3
    • Before proceeding farther take a good, clear photo of the PCB where the wires are all connected (Red Rectangle) Or carefully note down which wires go where. You will need this to complete the repair and reassemble the device.
    • Once you are prepared to replace them properly, remove the wires: Use a soldering iron to desolder each wire of the microphone.
    • Use proper technique, use flux, tin you iron and keep your iron in contact with joints no longer than necessary to achieve melting, or good joints. Avoid "cold joints", solder bridging, and excess heat. If those terms mean nothing to you, you should probably brush up on soldering before attempting this repair and practice a bit.
  5. Xbox Wireless Headset Microphone Replacement: 步骤 5 中的图像 1,3 Xbox Wireless Headset Microphone Replacement: 步骤 5 中的图像 2,3 Xbox Wireless Headset Microphone Replacement: 步骤 5 中的图像 3,3
    • Now, take your new microphone and solder each wire to the circuit board using your Soldering kit (Use the photo you took as a guide in connecting the wires).
    • Be careful of your iron placement. don't accidentally remove or damage the tiny SMDs. and don't melt the insulation on your wires. It you do, probably the best solution to avoid them shorting subsequently would be to re-do the joint and apply heat-shrink tubing, alternatively a bit of silicone cement to re-insulate them.
  6. Xbox Wireless Headset Microphone Replacement: 步骤 6 中的图像 1,2 Xbox Wireless Headset Microphone Replacement: 步骤 6 中的图像 2,2
    • Before you turn the headset on, INSPECT your work, look for any wires that have melted insulation that may short. Look for any imprecise solder joints where there is solder bridging to another pad. Are your joints nice and shiny? (good) or are they gray and grainy in appearance? (cold joints). fix any problems.
    • Recheck the wires are where they should be
    • Now, turn on the headset and check that the microphone works, if so, carefully reassemble your device.
    • If the microphone doesn't work, go back to the beginning of this step and check again
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Marvin
于01/21/25注册
133 声望
撰写一个指南
团队
3指南评论
Where can I buy a replacement microphone for the Xbox headset?
Michael Coronado - 回复
Same question here, I couldn't find one on eBay
Seeking Headset Microphone -
I am also looking for a replacement microphone for our XBox headphones. Mine looks the same as pictured in this article but only has a 2 wire set up.
Mike Potter - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 68
过去 30 天: 283
总计 1,351
