跳转到主内容
Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement
你所需要的
  1. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 步骤 2 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 步骤 2 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 步骤 2 中的图像 3,3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 3 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 3 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 3 中的图像 3,3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 步骤 4 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 步骤 4 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 步骤 4 中的图像 3,3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 步骤 5 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 步骤 5 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 步骤 5 中的图像 3,3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 6 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 6 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 步骤 6 中的图像 3,3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 步骤 7 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 步骤 7 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 步骤 7 中的图像 3,3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 步骤 8 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 步骤 8 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 步骤 8 中的图像 3,3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 步骤 9 中的图像 1,2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 步骤 10 中的图像 1,2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 步骤 10 中的图像 2,2
    • Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 步骤 11 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 步骤 11 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 步骤 11 中的图像 3,3
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 步骤 12 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 步骤 12 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 步骤 12 中的图像 3,3
    • Use your fingers to remove the joystick covers.
结论
6等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
15,619 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
一条评论
This was really helpful in fixing my thumbsticks. The only suggestion I have is to remove the battery cover after you're removed the handle covers instead of before. It will be easier to grip the controller while using the pry tools when the battery cover is still on.
Joshua Morden - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 149
过去 30 天: 643
总计 5,618
