跳转到主内容
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
你所需要的
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 步骤 1 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 步骤 1 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 步骤 1 中的图像 3,3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 步骤 2 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 步骤 2 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 步骤 2 中的图像 3,3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 步骤 3 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 步骤 3 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 步骤 3 中的图像 3,3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
结论
另外一个人完成了本指南。
Manuel Haeussermann
于07/13/22注册
16,286 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,068篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 104
总计 1,497
