跳转到主内容
Xbox Series X|S Controller (Model 1914) Back Housing Replacement
你所需要的
  1. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: 步骤 2 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: 步骤 2 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: 步骤 2 中的图像 3,3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 3 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 3 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 3 中的图像 3,3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: 步骤 4 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: 步骤 4 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: 步骤 4 中的图像 3,3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: 步骤 5 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: 步骤 5 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: 步骤 5 中的图像 3,3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 6 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 6 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: 步骤 6 中的图像 3,3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: 步骤 7 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: 步骤 7 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: 步骤 7 中的图像 3,3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: 步骤 8 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: 步骤 8 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: 步骤 8 中的图像 3,3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: 步骤 9 中的图像 1,2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: 步骤 10 中的图像 1,2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: 步骤 10 中的图像 2,2
    • Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: 步骤 11 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: 步骤 11 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: 步骤 11 中的图像 3,3
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: 步骤 12 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: 步骤 12 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: 步骤 12 中的图像 3,3
    • Insert the flat end of a spudger into the rectangular gap between the midframe assembly and back housing, nearest the left bumper.
    • Twist the spudger to partially release the midframe assembly.
    • Repeat this prying procedure on the gap near the right bumper to completely release the midframe assembly.
  13. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: 步骤 13 中的图像 1,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: 步骤 13 中的图像 2,3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: 步骤 13 中的图像 3,3
结论
4等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
15,619 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 100
过去 30 天: 410
总计 5,020
