简介
Use this guide to remove or replace the back housing on your Xbox Series X|S Controller (model 1914).
The back housing may need to be replaced if it's cracked, or you may be installing a new, customized one. The back housing is sometimes also called rear panel, backplate, back cover, or back shell.
你所需要的
Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
Remove the left handle cover.
Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
Remove the right handle cover.
Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
Insert the flat end of a spudger into the rectangular gap between the midframe assembly and back housing, nearest the left bumper.
Twist the spudger to partially release the midframe assembly.
Repeat this prying procedure on the gap near the right bumper to completely release the midframe assembly.
Lift up and remove the midframe assembly.
Only the back housing remains.
4等其他人完成本指南。
