此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
在本指南中,你将学习如何拆下位于扳机处的振动马达。此任务需要你将手柄上的扳机部分完全拆解。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
20等其他人完成本指南。
由衷感谢以下译者:
100%
k.terry.c正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
10指南评论
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - 回复 分享
My right trigger won't work on gta 5 and on other games it works
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - 回复 分享
