简介
This guide will teach you how to remove the rumble motors that are located in the grips of the controller.
你所需要的
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
13等其他人完成本指南。
7条评论
Hey I let my motor hang off when I was taking apart my controller and it tore off the motherboard on one side of my controller, is there a way to repair that?
Hi Mark,
Assuming that nothing beyond some solder came off with the wires, you can try resoldering the motor's wires back into place. Make sure to check exactly where they are meant to connect, and not to accidentally solder anything else on the board.
Liam Gow -
It would be nice to show the positioning of the motors in the frame since they are not symmetrical. The left one has a larger weight.
codekaizen - 回复
Where can I buy these rumble motors?
Steve Pepe - 回复
