跳转到主内容
Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment
你所需要的
  1. 在这个步骤中使用的工具:
    Essential Electronics Toolkit
    $23.96
  2. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 步骤 2 中的图像 1,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 步骤 2 中的图像 2,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 步骤 2 中的图像 3,3
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the batteries from your controller (if installed).
    • Remove the screw under the battery cover label. To do this, puncture the label where it is marked and use a TR8 driver or bit to remove the screw. TIP: This acrew us generally going to be found in the center of the label - feel around with your nail if need be to find it.
    • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
  3. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 步骤 3 中的图像 1,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 步骤 3 中的图像 2,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    • Author's note: I have no intention of retaking these photos as I do not have my 1697 anymore (and avoid them when possible). I can do this with one hand, but using a pry tool in the area marked in orange makes this easier.
    • With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
    • With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
    • Remove the shell once the battery tabs are released.
  4. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 步骤 4 中的图像 1,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 步骤 4 中的图像 2,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    • Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
    • Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
  5. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 步骤 5 中的图像 1,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 步骤 5 中的图像 2,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Precision Utility Knife
    • Repair one trigger at a time!
    • Before cutting the heatshrink, make TWO alignment marks (non-crossing).
    • After making alignment marks, cut the heatshrink off using a utility knife.
    • Using the old heatshrink as a reference, cut two new pieces.
  6. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 步骤 6 中的图像 1,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 步骤 6 中的图像 2,3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 步骤 6 中的图像 3,3
    • Incorrect magnet alignment will result in LT/RT activation without human input.
    • After cutting the heatshrink tubing, do a test alignment before applying glue.
    • These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
    • Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
  7. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 步骤 7 中的图像 1,2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 步骤 7 中的图像 2,2
    • A controller frame may be required if done incorrectly. Verify the alignment before adding glue!
    • After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
  8. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Install new heatshrink tubing: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Heat Shrink Tubing Assortment
    $7.99
    • Soft flame lighters may melt the plastic. Blue flame lighters are generally safer for this!
    • Once the glue cures, add new heatshrink tubing.
终点
9等其他人完成本指南。
Nick
于11/10/09注册
98,366 声望
创作了63篇指南
5指南评论
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
Eric Harper - 回复
same here cant find it any were
conman3609 -
check on aliexpress they have then in stock
Noob Gamer -
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
Chawki Bourokba - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 41
过去 30 天: 157
总计 25,522
