跳转到主内容
Xbox One Stereo Headset Microphone Replacement
你所需要的
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: 步骤 1 中的图像 1,3 Xbox One Stereo Headset Microphone Replacement, Microphone: 步骤 1 中的图像 2,3 Xbox One Stereo Headset Microphone Replacement, Microphone: 步骤 1 中的图像 3,3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: 步骤 3 中的图像 1,1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: 步骤 4 中的图像 1,3 Xbox One Stereo Headset Microphone Replacement: 步骤 4 中的图像 2,3 Xbox One Stereo Headset Microphone Replacement: 步骤 4 中的图像 3,3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: 步骤 5 中的图像 1,1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: 步骤 6 中的图像 1,1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
结论
4等其他人完成本指南。
Trevor Steele
于02/01/15注册
233 声望
撰写一个指南
团队
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G37
4 名成员
创作了5篇指南
9指南评论
Is a replacement microphone available from iFixit?
Scott Minton - 回复
What do you replace the mic with?
Its Me - 回复
They have the microphone for sale
daniel david guerrerogarcia - 回复
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - 回复
Any mod to make the cable removable?
kikis.andcream - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 24,478
