跳转到主内容
Xbox One Elite Controller (Model 1698) Motherboard Replacement
你所需要的
  1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: 步骤 1 中的图像 1,2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: 步骤 1 中的图像 2,2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Removing the back panel screws: 步骤 2 中的图像 1,1
    • Remove the 5 Torx Security Bit (TR9) screws.
  3. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: 步骤 3 中的图像 1,3 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: 步骤 3 中的图像 2,3 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: 步骤 3 中的图像 3,3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: 步骤 4 中的图像 1,2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: 步骤 4 中的图像 2,2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Screws on controller motherboard: 步骤 5 中的图像 1,1
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: 步骤 6 中的图像 1,2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: 步骤 6 中的图像 2,2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
  7. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: 步骤 7 中的图像 1,2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: 步骤 7 中的图像 2,2
    • Pull up from the "top" side of the controller on the daughterboard.
结论
9等其他人完成本指南。
EasyAsABC123
于01/22/10注册
2,491 声望
创作了5篇指南
1指南评论
50 minutes? half of that tops
glenn.fowell - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 117
总计 18,441
