跳转到主内容
Xbox One Elite Controller (Model 1698) Disassembly
你所需要的
  1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: 步骤 1 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: 步骤 1 中的图像 2,2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: 步骤 2 中的图像 1,1
    • Remove the 5 Torx Security Bit (TR9) screws.
  3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 步骤 3 中的图像 1,3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 步骤 3 中的图像 2,3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 步骤 3 中的图像 3,3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: 步骤 4 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: 步骤 4 中的图像 2,2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: 步骤 5 中的图像 1,1
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: 步骤 6 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: 步骤 6 中的图像 2,2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
  7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: 步骤 7 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: 步骤 7 中的图像 2,2
    • Pull up from the "top" side of the controller on the daughterboard.
  8. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 步骤 8 中的图像 1,3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 步骤 8 中的图像 2,3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 步骤 8 中的图像 3,3
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
  9. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: 步骤 9 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: 步骤 9 中的图像 2,2
    • Unscrew the 6 Torx (T6) screws.
  10. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: 步骤 10 中的图像 1,2 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: 步骤 10 中的图像 2,2
    • Now you can remove the buttons themselves.
结论
43等其他人完成本指南。
EasyAsABC123
于01/22/10注册
2,491 声望
创作了5篇指南
14指南评论
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - 回复
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph -
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - 回复
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - 回复
Thanks for the info
EasyAsABC123 -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 84
过去 30 天: 357
总计 102,737
