跳转到主内容
加入维修社区 - 创建账户
Xbox Elite Wireless Controller Series 2 Battery Replacement
你所需要的
  1. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 3,3
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the D-pad cover: 步骤 2 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the D-pad cover: 步骤 2 中的图像 2,2
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Battery Replacement, Disassembly information: 步骤 3 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Battery Replacement, Disassembly information: 步骤 3 中的图像 2,2
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 步骤 4 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 步骤 4 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 步骤 4 中的图像 3,3
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 5 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 5 中的图像 2,2
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 6 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 6 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 6 中的图像 3,3
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 7 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 7 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 7 中的图像 3,3
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 8 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 8 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 8 中的图像 3,3
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 9 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Battery Replacement: 步骤 9 中的图像 2,2
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 步骤 10 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 步骤 10 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 步骤 10 中的图像 3,3
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
  11. Xbox Elite Wireless Controller Series 2 Battery Replacement, Unfasten the midframe assembly: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    • If there's a white sticker covering one of the top screws, pierce through it with the screwdriver or use tweezers to remove it.
    • Use a Torx T8 Security screwdriver to remove the six 9 mm-long screws securing the midframe assembly.
    • Depending on the age and condition of your bit, a Torx T9 driver may fit better.
  12. Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 步骤 12 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 步骤 12 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 步骤 12 中的图像 3,3
    • The midframe assembly is held in place by three plastic clips and two metal rods.
    • Insert the flat end of a spudger under the top right edge of the midframe, just above the clip.
    • Pry up the midframe assembly to release the clips securing it.
  13. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 步骤 13 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 步骤 13 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 步骤 13 中的图像 3,3
    • Remove the midframe assembly.
    • During reassembly, align the triggers with the bottom housing before clipping the midframe assembly back in. If they aren't lined up correctly, the triggers might not work properly.
    • To reinstall the midframe assembly, lay it into the bottom housing and press firmly on the edges to engage the clips.
  14. Xbox Elite Wireless Controller Series 2 Battery Replacement, Unfasten the battery cover: 步骤 14 中的图像 1,1
    • Use a Torx T6 screwdriver to remove the four 6.9 mm-long screws securing the battery cover.
  15. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery cover: 步骤 15 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery cover: 步骤 15 中的图像 2,2
    • Remove the battery cover.
  16. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 步骤 16 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 步骤 16 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 步骤 16 中的图像 3,3
    • Grab the battery and lift it out of its recess.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Make sure to align the battery correctly by positioning the contacts on the bottom right of the battery on the prongs.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
24等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
24,606 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了25,162篇指南
13指南评论
Absolutely great tutorial, thank you. Now... any idea where I can get a replacement battery pack for this? Mine is deformed and unusable.
Kraeg Minett - 回复 分享
Hi Kraeg Minett, thanks for your comment! Unfortunately, the battery is currently not available at the iFixit Store, but you might have some luck looking for a replacement battery by either using the model code for the Elite Wireless Controller (1797) or the battery itself (DYND01).
Manuel Haeussermann - 分享
Hello.
Great tutorial
But - i cannot find replacement battery pack ( original one )
Please - can you help me with this issue ? Thank u
Stanislav Banas
Stanislav Baňas - 回复 分享
I got one here - https://kasynparts.com/product/xbox-elit...
Had it shipped to the UK and it arrived today after two weeks. I haven't yet installed it as now waiting for a T6 driver to arrive but might be worth a try.
Captain Lager - 回复 分享
Update - The repair was a success, the battery from the above website is good and the controller is now working again :)
Captain Lager - 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 185
过去 30 天: 895
总计 49,848
