跳转到主内容
X-Treme Tablet Generation 2 Battery Replacement
你所需要的
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: 步骤 2 中的图像 1,3 X-Treme Tablet Generation 2 Battery Replacement: 步骤 2 中的图像 2,3 X-Treme Tablet Generation 2 Battery Replacement: 步骤 2 中的图像 3,3
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: 步骤 3 中的图像 1,2 X-Treme Tablet Generation 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
结论
2等其他人完成本指南。
Mike Longshore
于01/28/15注册
125 声望
撰写一个指南
团队
Pasco Hernando, Team 5-4, Prince Winter 2015 Pasco Hernando, Team 5-4, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G4
6 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 1,231
