跳转到主内容
X-Street STR Viper Remote Control Motherboard Replacement
你所需要的
  1. X-Street STR Viper Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 1 中的图像 1,1
    • Turn off the remote control. Flip power switch to the off position.
    • Remove the battery from bottom of the remote control for further safety measures.
  2. X-Street STR Viper Remote Control Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove all seven 3mm Phillips #2 screws from the underside panel.
  3. X-Street STR Viper Remote Control Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove five 3mm Phillips #2 screws that connect the motherboard to the back outer shell.
  4. X-Street STR Viper Remote Control Motherboard Replacement: 步骤 4 中的图像 1,1
    • Detach the motherboard. Use soldering tools to desolder the red and black wires from the motherboard. To do this, refer to the how to solder/desolder page.
  5. X-Street STR Viper Remote Control Motherboard Replacement: 步骤 5 中的图像 1,1
    • Replace the motherboard. Solder the wires back on to the new motherboard using the soldering kit. The black wire should be on the left and the red wire should be on the right.
结论
Cate Kraska
于04/01/15注册
129 声望
撰写一个指南
团队
Cal Poly, Team 12-6, Lancaster Spring 2015 Cal Poly, Team 12-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 663
