当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Lift and remove the battery plate.
With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
Unplug outer case rumble motor connector from the motherboard with your fingers.
With your fingers, unplug the left speaker cable from the motherboard.
Remove the right speaker cable that's connected to the motherboard with the tweezers.
取消:我没有完成这个指南。
6等其他人完成本指南。
与7其他贡献者
于02/10/16注册
3,357 声望
创作了7篇指南
徽章: 16
+ 13更多徽章
USFT-SULLIVAN-S16S1G6
4 名成员
创作了40篇指南
Awesome guide, replacement speakers worked flawlessly!!
Christopher Harris - 2016年9月2日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 66
总计 4,420
