跳转到主内容
Why You Should Clean and Maintain Your Automatic Coffeemaker
你所需要的
    • Remove all loose attachments such as the water tank, drip tray, and coffee beans. Open the machine using this guide.
    • Inspect the water hoses and internal components for any signs of contamination.
    • The hoses don’t always need to be replaced. Often, cleaning with a thin brush, detergent, and hot water is sufficient.
    • Remove the screw on the cover. Remove the cover.
    • Unscrew the brewing unit.
    • Carefully remove the brewing unit for inspection and cleaning.
    • Detach the drainage valve to check for internal contamination.
    • This guide shows, how to overhaul the drainage valve.
    • Pre-clean parts before placing them in an ultrasonic bath for deep cleaning.
    • If you don’t have access to an ultrasonic bath, clean all parts thoroughly with hot water and detergent. Avoid using a dishwasher.
    • Install new or cleaned hoses and replace any worn-out seals.
    • Thorough cleaning of the interior and exterior is necessary.
    • The coffee spout tends to become contaminated with coffee grease. If you want to remove it, you have to remove the spout, which can be quite time-consuming.
    • After cleaning and replacing necessary parts, reassemble the machine.
    • Run a cleaning and descaling cycle before brewing coffee again.
结论
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
另外一个人完成了本指南。
eCuration
于05/19/17注册
450,149 声望
创作了252篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,638篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 571
总计 1,412
