跳转到主内容
Whirlpool WED87HED Dryer Heating Element Testing and Replacement
你所需要的
  1. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Safety Precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the top panel: 步骤 3 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 4 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 4 中的图像 2,2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the control panel: 步骤 5 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the control panel: 步骤 5 中的图像 2,2
    • Disconnect the control panel cable from the main board.
  6. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 6 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 6 中的图像 2,2
    • Disconnect the drum light connector.
  7. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the control panel: 步骤 7 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the control panel: 步骤 7 中的图像 2,2
    • Use a 1/4 inch nut driver to remove the two 16.3 mm‑long sheet metal screws located at each end of the control panel.
  8. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the control panel: 步骤 8 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the control panel: 步骤 8 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the control panel: 步骤 8 中的图像 3,3
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 3,3
    • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
    • Unplug the connector.
  10. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the front panel: 步骤 10 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the front panel: 步骤 10 中的图像 2,2
    • Use a 1/4 inch nut driver to remove the three upper front panel 16.4 mm-long sheet metal screws.
    • Tilt the machine backwards and prop it securely, or have a friend hold it.
    • Use a 1/4 inch nut driver to remove the four sheet metal screws on the bottom edge of the panel:
    • Two 16.4 mm screws
    • Two 13 mm screws
  11. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips driver to remove the two 15.8 mm‑long screws inside the door area below the drum opening.
  12. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the front panel: 步骤 12 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the front panel: 步骤 12 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the front panel: 步骤 12 中的图像 3,3
    • The panel is heavy and awkward. You may want to have a friend help you with this step.
    • Pull the bottom of the panel away from the chassis about two to three inches.
    • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
    • Make sure you don't snag the door switch wire harness as you remove the panel.
  13. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the cover plate: 步骤 13 中的图像 1,1
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  14. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 3,3
    • Remove the cover plate.
  15. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the cord: 步骤 15 中的图像 1,1
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  16. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cord: 步骤 16 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cord: 步骤 16 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the cord: 步骤 16 中的图像 3,3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  17. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the cord terminal block: 步骤 17 中的图像 1,1
    • Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
    • Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
  18. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 3,3
    • Move the cord terminal block behind the rear panel.
  19. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the rear panel: 步骤 19 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the rear panel: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Use a 1/4 inch nut driver to remove the eleven rear panel screws.
    • Ten 20 mm-long screws
    • One 12.9 mm-long screw under the water inlet.
  20. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 20 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 20 中的图像 2,2
    • Use a 1/4 inch nut driver to remove the 16.4 mm-length screw holding the main board bracket to the chassis.
    • Use a 1/4 inch nut driver to remove the two 20 mm-long screws from the top rear of the machine.
  21. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 3,3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  22. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Reassembly information: 步骤 22 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Reassembly information: 步骤 22 中的图像 2,2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  23. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 3,3
    • Pull the lint filter up out of the lint filter slot to remove it.
    • These photos show the front panel in place, but the procedure is the same if the front panel is already removed.
  24. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the lint filter housing: 步骤 24 中的图像 1,1
    • Use a 1/4 inch nut driver to remove the 16.4 mm‑long mounting screws securing the lint filter housing.
  25. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 3,3
    • Pull the filter housing outward from the chassis and down to remove it.
  26. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 3,3
    • Squeeze the locking tabs on the moisture sensor connector.
    • Disconnect the connector.
  27. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 3,3
    • Label, photograph or make a sketch of the connector locations and of the main board bracket position on your machine.
    • Disconnect all of the connectors on the main board front half.
  28. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 28 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 28 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 28 中的图像 3,3
    • Disconnect all the connectors from the rear half of the main board.
  29. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the main board from the main board bracket: 步骤 29 中的图像 1,1
    • Use a 1/4 inch nut driver to remove the 12.8 mm‑long sheet metal screw that retains the main board to the main board bracket.
  30. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 3,3
    • Lift the rear corner of the main board nearest to the side walls of the chassis.
    • You want to release the locking tab on the side of the main board.
    • Slide the main board toward the front of the dryer to release the tabs securing it to the main board bracket.
  31. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the main board: 步骤 31 中的图像 1,1
    • Remove the main board from the main board bracket.
  32. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the main board bracket: 步骤 32 中的图像 1,1
    • Use a 1/4 inch nut driver to unfasten the 16.4 mm‑long sheet metal screw holding the main board bracket.
  33. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 3,3
    • Lift off the main board bracket from the chassis and turn it so the bottom is exposed.
    • Using long nose or slip joint pliers, pinch the locking wings of the harness retainer clamp.
    • Separate the harness from the main board bracket and remove the main board bracket.
  34. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 3,3
    • Use a 1/4 inch nut driver to remove the two screws securing the upper front bulkhead to the front of the chassis.
    • One 16.4 mm-long sheet metal screw
    • One 19.8 mm-long sheet metal screw
    • Use a 1/4 inch nut driver to remove the two 16.5 mm‑long sheet metal screws securing the top plastic portion to the upper front bulkhead.
  35. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 3,3
    • Remove the upper front bulkhead and set it aside.
  36. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Release the belt tension: 步骤 36 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Release the belt tension: 步骤 36 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Release the belt tension: 步骤 36 中的图像 3,3
    • Take careful note of the belt path before proceeding.
    • Be very careful during this step! The idler arm is under spring tension and may pinch you, or it could damage the belt switch if the arm is allowed to snap down.
    • Push the idler arm (the metal upside-down "L") up to relieve the tension on the drive belt.
    • Remove the belt from the motor pulley.
    • Gently lower the idler arm until it rests parallel to the dryer floor.
    • During reassembly, refer to your notes or the belt path link to rethread the drive belt.
  37. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the lower front bulkhead: 步骤 37 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the lower front bulkhead: 步骤 37 中的图像 2,2
    • Use a 1/4 inch nut driver to remove the four screws securing the lower front bulkhead.
    • Two 16.1 mm-long sheet metal screws on the left side of the lower front bulkhead.
    • Two 13.2 mm-long sheet metal screws on the right side of the lower front bulkhead.
  38. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 3,3
    • While supporting the drum, lift the lower front bulkhead off of the hooks on the chassis.
  39. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 39 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 39 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 39 中的图像 3,3
    • Lower the bulkhead about 2 inches to free the drum rollers tucked under the drum.
    • While supporting the drum, remove the lower front bulkhead.
    • During reassembly, tilt the bulkhead to the right to get the rollers under the lip on the front of the drum. Once the drum is on the rollers, you can move the bulkhead to the upright position.
  40. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the drum: 步骤 40 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the drum: 步骤 40 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the drum: 步骤 40 中的图像 3,3
    • Use the belt to lift the drum a few inches.
    • Swing the drum out of the front of the dryer.
    • Note which end of the drum faces the front.
    • If the belt is broken, stand in front of the drum and put your arms inside it. Lift it up and pull it through the front opening of the machine. Having someone to help you with this is a good idea.
    • Make sure you get your drum back on the rollers when you reinstall the lower front bulkhead. Take your time and don't force it.
  41. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Heating element information: 步骤 41 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Heating element information: 步骤 41 中的图像 2,2
    • The next four steps show disconnecting the heating element.
  42. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the heating element: 步骤 42 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the heating element: 步骤 42 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the heating element: 步骤 42 中的图像 3,3
    • Disconnect the three spade connectors attached to the heating element.
    • Note the locations of the spade connectors.
    • Pull on the connectors and not the wires themselves.
    • If you are just replacing the heating element and don't need to test it, you can skip the next two steps and move to here.
  43. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Test the heating element: 步骤 43 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Test the heating element: 步骤 43 中的图像 2,2
    • These steps will require a multimeter. If you aren't familiar with how to use one, here is a guide that will help you
    • You will first check the resistance between the middle common terminal and each of the element terminals.
    • The resistance should be about 20 ohms (Ω). If the resistance is less than 18 Ω, or greater than 25 Ω, you should replace the element.
  44. Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 44 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement: 步骤 44 中的图像 2,2
    • Check the resistance between the top and bottom terminals.
    • The multimeter should read about 40 Ω.
    • Check resistance from the middle terminal to the heater housing.
    • The multimeter should read OL or "—"
    • If the element has the correct values when tested, you can stop here. You don't have to replace the heating element. As a precaution, while everything is accessible, you may want to test the components located on the heater housing.
    • For the hi limit thermostat/inlet thermistor combined component follow this link
    • For the thermal cutoff switch follow this link.
  45. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Hi-limit thermostat/inlet thermistor information: 步骤 45 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Hi-limit thermostat/inlet thermistor information: 步骤 45 中的图像 2,2
    • The next four steps show how to disconnect and remove the hi-limit thermostat and inlet thermistor.
    • The hi-limit thermostat and inlet thermistor are housed in one unit. Some dryers may not have an inlet thermistor.
  46. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor unit: 步骤 46 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor unit: 步骤 46 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor unit: 步骤 46 中的图像 3,3
    • Pull the spade connectors straight off to disconnect the hi-limit thermostat portion of the hi-limit thermostat/inlet thermistor unit.
  47. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the inlet thermistor: 步骤 47 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the inlet thermistor: 步骤 47 中的图像 2,2
    • Free the inlet thermistor connector by lifting the black locking tab with a small flathead screwdriver or spudger.
    • The black locking tab is fragile, so only lift it a small amount to free the connector. Make sure to grasp the connector, not the wires when removing them.
    • Once freed, pull the connector straight out to disconnect the inlet thermistor.
  48. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the hi-limit thermostat/ inlet thermistor: 步骤 48 中的图像 1,1
    • Use a 1/4 inch nut driver to remove the two 12.8 mm long sheet metal screws securing the hi-limit thermostat/inlet thermistor unit.
  49. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the hi limit thermostat/ inlet thermistor: 步骤 49 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the hi limit thermostat/ inlet thermistor: 步骤 49 中的图像 2,2
    • Remove the unit by pulling it straight out from the mounting hole.
    • Note the orientation with the thermistor connector to the rear of the machine for reassembly.
  50. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Thermal cutoff switch information: 步骤 50 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Thermal cutoff switch information: 步骤 50 中的图像 2,2
    • The following three steps show how to remove the thermal cutoff switch.
  51. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the thermal cutoff switch: 步骤 51 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the thermal cutoff switch: 步骤 51 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Disconnect the thermal cutoff switch: 步骤 51 中的图像 3,3
    • Pull the two thermal cutoff switch spade connectors straight out of their slots to disconnect them.
    • Make sure to grasp the connectors and not the wires when disconnecting.
  52. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the thermal cutoff switch: 步骤 52 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the thermal cutoff switch: 步骤 52 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the thermal cutoff switch: 步骤 52 中的图像 3,3
    • Use a 1/4 inch nut driver to remove the two 12.8 mm-length sheet metal screws securing the thermal cutoff switch.
    • Note the orientation of the part, as there is a tab on the lower part of the heater housing that allows the part to fit properly only one way. The screw tabs are angled slightly to facilitate this.
  53. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the thermal cutoff switch: 步骤 53 中的图像 1,2 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the thermal cutoff switch: 步骤 53 中的图像 2,2
    • Remove the thermal cutoff switch by lifting it off of the heater housing.
  54. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Unfasten the heater housing cover: 步骤 54 中的图像 1,1
    • Use a 1/4 inch nut driver to remove the four 12.8 mm‑long sheet metal screws securing the heater housing cover.
  55. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heater housing cover: 步骤 55 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heater housing cover: 步骤 55 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heater housing cover: 步骤 55 中的图像 3,3
    • Put on gloves before continuing, as the heater housing cover is sharp
    • Lift the front of the heater housing cover to release the tabs securing it to the inlet housing pipe.
    • Make sure to lift the end of the cover well up so that you can get this tab to come free. Also the tabs on the side of the housing can stick in the slots.
    • Remove the heater housing cover.
    • During reassembly, make sure all the tabs on the cover have gone all the way through the slots on the sides of the housing and on the heating element. It will snap into place when it is correct.
  56. Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heating element: 步骤 56 中的图像 1,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heating element: 步骤 56 中的图像 2,3 Whirlpool WED87HED Dryer Heating Element Testing and Replacement, Remove the heating element: 步骤 56 中的图像 3,3
    • Lift the heating element out of the slots in the lower part of the heater housing.
    • Remove the heating element.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
30,797 声望
创作了213篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 175
