跳转到主内容
Whirlpool Refrigerator Icemaker Auger Assembly Replacement
你所需要的
  1. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker tray: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker tray: 步骤 3 中的图像 2,2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 3,3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 3,3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: 步骤 7 中的图像 1,1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker auger assembly: 步骤 8 中的图像 1,1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 1,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 2,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 3,3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 3,3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker auger assembly: 步骤 11 中的图像 1,1
    • Remove the icemaker auger assembly.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 100
