跳转到主内容
Whirlpool Refrigerator Auger Motor Replacement
你所需要的
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: 步骤 3 中的图像 2,2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 3,3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 3,3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: 步骤 7 中的图像 1,1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: 步骤 8 中的图像 1,1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 3,3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 3,3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: 步骤 11 中的图像 1,1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 3,3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: 步骤 13 中的图像 1,1
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: 步骤 14 中的图像 1,1
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: 步骤 15 中的图像 1,2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: 步骤 15 中的图像 2,2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: 步骤 16 中的图像 1,3 Whirlpool Refrigerator Auger Motor Replacement: 步骤 16 中的图像 2,3 Whirlpool Refrigerator Auger Motor Replacement: 步骤 16 中的图像 3,3
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: 步骤 17 中的图像 1,1
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: 步骤 18 中的图像 1,1
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 32
总计 2,148
