跳转到主内容
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
你所需要的
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: 步骤 1 中的图像 1,1
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 2 中的图像 1,1
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 3 中的图像 1,1
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 4 中的图像 1,1
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 5 中的图像 1,1
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 6 中的图像 1,1
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 7 中的图像 1,2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 7 中的图像 2,2
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 8 中的图像 1,2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 8 中的图像 2,2
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 9 中的图像 1,1
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 10 中的图像 1,1
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 11 中的图像 1,1
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 12 中的图像 1,1
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 13 中的图像 1,1
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 14 中的图像 1,1
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 15 中的图像 1,1
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 16 中的图像 1,1
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 步骤 17 中的图像 1,1
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 36
总计 1,346
