跳转到主内容
Wacom Intuos4 Motherboard Replacement
你所需要的
  1. Wacom Intuos4 Motherboard Replacement, Casing: 步骤 1 中的图像 1,3 Wacom Intuos4 Motherboard Replacement, Casing: 步骤 1 中的图像 2,3 Wacom Intuos4 Motherboard Replacement, Casing: 步骤 1 中的图像 3,3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Motherboard Replacement: 步骤 2 中的图像 1,2 Wacom Intuos4 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Wacom Intuos4 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Motherboard Replacement: 步骤 4 中的图像 1,2 Wacom Intuos4 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Motherboard Replacement: 步骤 5 中的图像 1,2 Wacom Intuos4 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
结论
Jack Palmgren
于10/26/22注册
234 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 279
