跳转到主内容
WRS315SDHW Refrigerator Thermistor Replacement
你所需要的
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: 步骤 2 中的图像 1,3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: 步骤 2 中的图像 2,3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: 步骤 3 中的图像 1,2 WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: 步骤 3 中的图像 2,2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: 步骤 4 中的图像 1,3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: 步骤 4 中的图像 2,3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: 步骤 4 中的图像 3,3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: 步骤 5 中的图像 1,3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: 步骤 5 中的图像 2,3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: 步骤 5 中的图像 3,3
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: 步骤 6 中的图像 1,1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: 步骤 7 中的图像 1,3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: 步骤 7 中的图像 2,3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: 步骤 7 中的图像 3,3
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: 步骤 8 中的图像 1,2 WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: 步骤 8 中的图像 2,2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 191
