跳转到主内容
WRS315SDHW Defrost Thermistor Replacement
你所需要的
  1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: 步骤 2 中的图像 1,3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: 步骤 2 中的图像 2,3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: 步骤 3 中的图像 1,2 WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: 步骤 3 中的图像 2,2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Thermistor Replacement: 步骤 4 中的图像 1,2 WRS315SDHW Defrost Thermistor Replacement: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 1,3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 2,3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 3,3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 1,3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 2,3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 3,3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 1,3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 2,3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 3,3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: 步骤 8 中的图像 1,2 WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: 步骤 8 中的图像 2,2
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: 步骤 9 中的图像 1,1
    • Remove the thermistor.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
34 名成员
创作了593篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 129
