跳转到主内容
WRS315SDHW Control Board Replacement
你所需要的
  1. WRS315SDHW Control Board Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 1,2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 2,2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 1,3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 2,3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 3,3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: 步骤 4 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: 步骤 5 中的图像 1,3 WRS315SDHW Control Board Replacement: 步骤 5 中的图像 2,3 WRS315SDHW Control Board Replacement: 步骤 5 中的图像 3,3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 1,3 WRS315SDHW Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 2,3 WRS315SDHW Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 3,3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: 步骤 7 中的图像 1,2 WRS315SDHW Control Board Replacement: 步骤 7 中的图像 2,2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: 步骤 8 中的图像 1,1
    • Remove the control board.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 635
