简介
Use this guide to replace the control board in your Whirlpool WRS315SDHW Refrigerator.
The control board processes the inputs for the dispenser assembly and other related assemblies. If your refrigerator is not dispensing properly, or if the dispenser buttons on your refrigerator aren't working, then your control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
你所需要的
Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
Pull the dispenser panels straight down to separate them from the chassis.
Remove the dispenser panels.
Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
Disconnect the large connector attached to the right edge of the control board.
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
