跳转到主内容
Vtech Kidizoom Smart Watch DX Circuit Board Replacement
你所需要的
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: 步骤 1 中的图像 1,1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 4 中的图像 1,2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 2,2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 8 中的图像 1,1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
结论
7等其他人完成本指南。
团队
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G6
4 名成员
创作了12篇指南
2指南评论
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - 回复
Where can I buy replacement and how much should it cost?
Marisol Pelayo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 43
总计 10,840
