跳转到主内容
Vtech Kidizoom Smart Watch DX Battery Replacement
你所需要的
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: 步骤 1 中的图像 1,1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 3 中的图像 1,1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 4 中的图像 1,2 Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: 步骤 5 中的图像 1,2 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: 步骤 5 中的图像 2,2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 7 中的图像 1,1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 8 中的图像 1,1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 9 中的图像 1,1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: 步骤 10 中的图像 1,2 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 11 中的图像 1,1
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 12 中的图像 1,1
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: 步骤 13 中的图像 1,1
    • Pull the battery free, and wait for the solder to cool before handling further.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G6
4 名成员
创作了12篇指南
一条评论
Where did you bought the battery?
funkysoulbrother - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 56
总计 9,070
