跳转到主内容
Vtech Innotab 3 Speaker Replacement
你所需要的
  1. Vtech Innotab 3 Speaker Replacement, Rear Panel: 步骤 1 中的图像 1,3 Vtech Innotab 3 Speaker Replacement, Rear Panel: 步骤 1 中的图像 2,3 Vtech Innotab 3 Speaker Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Speaker Replacement: 步骤 3 中的图像 1,3 Vtech Innotab 3 Speaker Replacement: 步骤 3 中的图像 2,3 Vtech Innotab 3 Speaker Replacement: 步骤 3 中的图像 3,3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Speaker Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Vtech Innotab 3 Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Vtech Innotab 3 Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • After you disassemble the device, put the back panel to the side and move your attention to the front piece.
    • Remove the four screws using a PH00 screwdriver.
  6. Vtech Innotab 3 Speaker Replacement: 步骤 6 中的图像 1,2 Vtech Innotab 3 Speaker Replacement: 步骤 6 中的图像 2,2
    • Using a nylon or metal spudger, lift the blue plastic piece upwards.
    • Keeping the plastic piece lifted, carefully pinch the edge of the speaker and remove it.
    • Be sure not to tug on the speaker too violently to prevent tearing a wiring from its solder.
  7. Vtech Innotab 3 Speaker Replacement: 步骤 7 中的图像 1,3 Vtech Innotab 3 Speaker Replacement: 步骤 7 中的图像 2,3 Vtech Innotab 3 Speaker Replacement: 步骤 7 中的图像 3,3
结论
Zach Diviney
于03/11/15注册
419 声望
创作了4篇指南
团队
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 740
