跳转到主内容
Vtech Innotab 3 Microphone Replacement
你所需要的
  1. Vtech Innotab 3 Microphone Replacement, Rear Panel: 步骤 1 中的图像 1,3 Vtech Innotab 3 Microphone Replacement, Rear Panel: 步骤 1 中的图像 2,3 Vtech Innotab 3 Microphone Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Microphone Replacement: 步骤 3 中的图像 1,3 Vtech Innotab 3 Microphone Replacement: 步骤 3 中的图像 2,3 Vtech Innotab 3 Microphone Replacement: 步骤 3 中的图像 3,3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Microphone Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Microphone Replacement, Microphone: 步骤 5 中的图像 1,3 Vtech Innotab 3 Microphone Replacement, Microphone: 步骤 5 中的图像 2,3 Vtech Innotab 3 Microphone Replacement, Microphone: 步骤 5 中的图像 3,3
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift up the circuit board from the device.
  6. Vtech Innotab 3 Microphone Replacement: 步骤 6 中的图像 1,3 Vtech Innotab 3 Microphone Replacement: 步骤 6 中的图像 2,3 Vtech Innotab 3 Microphone Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • To replace the microphone, desolder the two connections that connect the speaker to the device.
    • Use tweezers to keep the microphone steady as you desolder the connections.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
结论
Zach Diviney
于03/11/15注册
419 声望
创作了4篇指南
团队
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 339
