简介
In order to replace the headphone port grab yourself a PH00 screwdriver, a metal spudger, and a soldering kit.
- Before you begin disassembling the Vtech InnoTab 3, turn on your soldering iron. If working with others let them know that the soldering iron is on and to use caution.
你所需要的
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
在这个步骤中使用的工具:Tweezers$4.99
On the front panel of the device, the headphone poet is located at the bottom right corner of the device, opposte of the speaker.
Using tweezers, lift up to remove the headphone port from its holding.
另外一个人完成了本指南。
