简介
If the volume of your Vizio SmartCast Crave 360 (model SP50-DP) is not responding to the movement of the speaker ring, use this guide to replace the speaker ring. The speaker ring utilizes a ball bearing and other moving objects to allow users to adjust the volume of their speaker.
Before replacing the speaker ring, consult the troubleshooting page to resolve any other possible issues that could be causing the volume to not work.
你所需要的
Using the halberd spudger, pop off the metal disc that is connected to the speaker ring.
Remove the metal disc.
