跳转到主内容
Vizio SmartCast Crave 360 Battery Replacement
你所需要的
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: 步骤 3 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement: 步骤 3 中的图像 2,2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: 步骤 4 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement, Bass: 步骤 4 中的图像 2,2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: 步骤 5 中的图像 1,3 Vizio SmartCast Crave 360 Battery Replacement: 步骤 5 中的图像 2,3 Vizio SmartCast Crave 360 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: 步骤 6 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: 步骤 7 中的图像 1,1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: 步骤 8 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement: 步骤 8 中的图像 2,2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: 步骤 9 中的图像 1,2 Vizio SmartCast Crave 360 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard from the battery.
结论
另外一个人完成了本指南。
一条评论
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 78
总计 1,128
