跳转到主内容
Vizio SmartCast Crave 360 Bass Replacement
你所需要的
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: 步骤 3 中的图像 1,2 Vizio SmartCast Crave 360 Bass Replacement: 步骤 3 中的图像 2,2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: 步骤 4 中的图像 1,2 Vizio SmartCast Crave 360 Bass Replacement, Bass: 步骤 4 中的图像 2,2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: 步骤 5 中的图像 1,3 Vizio SmartCast Crave 360 Bass Replacement: 步骤 5 中的图像 2,3 Vizio SmartCast Crave 360 Bass Replacement: 步骤 5 中的图像 3,3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 677
