跳转到主内容
Vivitar Vivicam T027 Power Button Replacement
你所需要的
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Vivitar Vivicam T027 Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: 步骤 3 中的图像 1,2 Vivitar Vivicam T027 Power Button Replacement: 步骤 3 中的图像 2,2
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: 步骤 5 中的图像 1,2 Vivitar Vivicam T027 Power Button Replacement: 步骤 5 中的图像 2,2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
结论
Dana
于03/11/15注册
110 声望
撰写一个指南
团队
Marist, Team 15-13, Laflen Spring 2015 Marist, Team 15-13, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S15G13
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 914
