跳转到主内容
Visual Land Prestige Pro 7D Battery Replacement
你所需要的
  1. Visual Land Prestige Pro 7D Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Battery Replacement: 步骤 2 中的图像 1,1
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Pry a thin tool under the battery.
    • Be gentle and try not to bend the battery.
    • Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
  4. Visual Land Prestige Pro 7D Battery Replacement: 步骤 4 中的图像 1,2 Visual Land Prestige Pro 7D Battery Replacement: 步骤 4 中的图像 2,2
    • Soldering guns are hot and can easily damage the device.
    • Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
    • For soldering information, see our guide: 如何焊接和拆焊.
    • If you are removing the LCD display this step is unnecessary.
结论
3等其他人完成本指南。
Max Hudson
于10/14/14注册
422 声望
创作了2篇指南
团队
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G41
4 名成员
创作了12篇指南
1指南评论
My tablet shows the icon battery What that mean
paularslay - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 6,227
