跳转到主内容
Visual Land Prestige Elite 9Q Battery Replacement
你所需要的
  1. Visual Land Prestige Elite 9Q Battery  Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connection begin to loosen.
  2. Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 2 中的图像 1,1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast.
  3. Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 3 中的图像 1,2 Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 3 中的图像 2,2
    • Once all connections have been loosened and using a soft surface, place the device onto its screen, and lift gently on the outer casing.
    • Open the casing and lay as shown keeping the speaker wires loose.
  4. Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 4 中的图像 1,2 Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use wide tip tweezers to gently remove the three pieces of tape attached to battery.
    • Once the tape has been removed, the battery will be free from the tablet except for the wired connections to the circuit board.
    • Be careful not to severely damage the tape as this is what will hold the battery in place.
    • Mark where the positive (red) and negative (black) wires are on the circuit board.
    • Markings will be used for reassembly.
  5. Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 5 中的图像 1,2 Visual Land Prestige Elite 9Q Battery  Replacement: 步骤 5 中的图像 2,2
    • Before disconnecting battery, review Soldering Tips to ensure proper soldering.
    • Use soldering iron to remove +(red) battery lead.
    • Touch the positive wire to a metal surface acting as a ground to discharge the battery. Depending on the charge level of the battery, it may take up to 30 seconds to insure that it is fully discharged.
    • 'Ensure that the wires and solder do not touch each other, for this will damage the device
    • Remove the -(black) battery lead.
    • Remove and discard the old battery. Insert new battery and solder the positive and then the negative terminals to the circuit board.
结论
2等其他人完成本指南。
LAWRENCE SMITH
于07/19/16注册
108 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,401
