跳转到主内容
Velocity Micro Cruz Speaker Replacement
你所需要的
  1. Velocity Micro Cruz Speaker Replacement, Remove the Back: 步骤 1 中的图像 1,1
    • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
    • Gently work the tool around the diameter of the tablet until the back pops completely off.
  2. Velocity Micro Cruz Speaker Replacement, Remove All Screws: 步骤 2 中的图像 1,2 Velocity Micro Cruz Speaker Replacement, Remove All Screws: 步骤 2 中的图像 2,2
    • Use the screwdrivers to remove all the screws.
    • Ensure that all screws are removed before moving on to the next step.
  3. Velocity Micro Cruz Speaker Replacement, Remove LCD Connector: 步骤 3 中的图像 1,1
    • Remove the bottom LCD connector by gently pulling it away from the motherboard.
  4. Velocity Micro Cruz Speaker Replacement, Separate the Frame from the Housing: 步骤 4 中的图像 1,1
    • Identify the speaker wires.
    • Use a plastic opening tool to gently pry underneath the frame of the grey plastic frame until it completely separates from the housing.
  5. Velocity Micro Cruz Speaker Replacement, Remove and Replace the Speaker: 步骤 5 中的图像 1,1
    • Use the wire cutters to clip the speaker wires in the middle
    • Use a plastic opening tool to remove the speaker.
    • Insert the new speaker in its place and solder the old and new wires together.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
结论
T Smith
于11/02/16注册
205 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 113
