跳转到主内容
Valve Index Headset Head Strap Replacement
你所需要的
  1. Valve Index Headset Head Strap Replacement, Adjust the eye tube relief: 步骤 1 中的图像 1,1
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: 步骤 2 中的图像 1,3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: 步骤 2 中的图像 2,3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: 步骤 2 中的图像 3,3
    • Insert an opening pick between the eye relief knob and the head strap.
    • Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
  3. Valve Index Headset Head Strap Replacement, Reassembly tip: 步骤 3 中的图像 1,1
    • During reassembly, ensure the eye relief knob is aligned with the shaft before pressing it on.
  4. Valve Index Headset Head Strap Replacement, Remove the head strap clip: 步骤 4 中的图像 1,3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: 步骤 4 中的图像 2,3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  5. Valve Index Headset Head Strap Replacement, Remove the face gasket: 步骤 5 中的图像 1,2 Valve Index Headset Head Strap Replacement, Remove the face gasket: 步骤 5 中的图像 2,2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  6. Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: 步骤 6 中的图像 1,2 Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: 步骤 6 中的图像 2,2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  7. Valve Index Headset Head Strap Replacement, Disconnect the tether cable: 步骤 7 中的图像 1,2 Valve Index Headset Head Strap Replacement, Disconnect the tether cable: 步骤 7 中的图像 2,2
    • Pull the tether cable straight back out of the headset.
  8. Valve Index Headset Head Strap Replacement, Head strap removal information: 步骤 8 中的图像 1,2 Valve Index Headset Head Strap Replacement, Head strap removal information: 步骤 8 中的图像 2,2
    • The head strap can be removed without removing the face gasket bezel if you have the correct length driver. If you are using your iFixit T6 driver, skip this step and proceed with removing the face gasket bezel.
    • Your T6 driver must have a shaft longer than 18 mm (0.7 in) and an overall length less than 140 mm (5.5 in).
    • Insert your T6 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
    • Skip to step 12.
  9. Valve Index Headset Head Strap Replacement, Remove the face gasket bezel: 步骤 9 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  10. Valve Index Headset Head Strap Replacement: 步骤 10 中的图像 1,2 Valve Index Headset Head Strap Replacement: 步骤 10 中的图像 2,2
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
  11. Valve Index Headset Head Strap Replacement: 步骤 11 中的图像 1,3 Valve Index Headset Head Strap Replacement: 步骤 11 中的图像 2,3 Valve Index Headset Head Strap Replacement: 步骤 11 中的图像 3,3
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
  12. Valve Index Headset Head Strap Replacement, Remove the head strap: 步骤 12 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
  13. Valve Index Headset Head Strap Replacement: 步骤 13 中的图像 1,2 Valve Index Headset Head Strap Replacement: 步骤 13 中的图像 2,2
    • Pull the right end of the head strap straight off of the headset.
    • During reassembly, ensure the head strap is correctly positioned on the alignment post.
  14. Valve Index Headset Head Strap Replacement: 步骤 14 中的图像 1,2 Valve Index Headset Head Strap Replacement: 步骤 14 中的图像 2,2
    • Use a T6 Torx screwdriver to loosen the screw securing the left side of the head strap to the headset.
    • Don't let this screw fall inside the headset. It is not a captive screw and is difficult to retrieve.
    • If the black plastic cap surrounding the cap limits access, use an opening pick to remove the cap.
  15. Valve Index Headset Head Strap Replacement: 步骤 15 中的图像 1,2 Valve Index Headset Head Strap Replacement: 步骤 15 中的图像 2,2
    • Pull the left end of the head strap straight off the headset.
    • During reassembly, be careful not to let the screw fall into the headset. Use your driver to hold it in place from behind if necessary.
  16. Valve Index Headset Head Strap Replacement: 步骤 16 中的图像 1,2 Valve Index Headset Head Strap Replacement: 步骤 16 中的图像 2,2
    • Slide the head strap band out from the headset.
    • The head strap is now fully removed.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
24等其他人完成本指南。
Sam Omiotek
于02/25/19注册
75,456 声望
创作了288篇指南
7条评论
I'm having troubles with my left speaker, I just got done replacing it, is this the next step I wanna try in troubleshooting it? The last thing I want to do is buy a whole new headset? It cuts out when the strap moves. I've already replaced the cable as well.
Who? - 回复
Try to tighten left part of the strap (step 14)
Анатолий Прилуцкий -
When will they be in stock again
lightning gaming - 回复
Any word on restocking for this part?
Charles Allen - 回复
No stock for 2 Years now. Great...
Ricky Bobby - 回复
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 234
过去 30 天: 1,249
总计 31,549
