跳转到主内容
Valve Index Headset Head Strap Clip Replacement
你所需要的
  1. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: 步骤 1 中的图像 1,3 Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: 步骤 1 中的图像 2,3 Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: 步骤 1 中的图像 3,3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3等其他人完成本指南。
Sam Omiotek
于02/25/19注册
73,134 声望
创作了288篇指南
7条评论
Why are these clips so expensive? At $39.99 it's like someone mashed an extra 9 when putting in the price, the face gasket which is much larger, uses more material and is more robust costs less than half, even the power adapters are $5 cheaper.
Dor - 回复
Seems that the price has been corrected to $4.99
Dor -
Yeah. The price is seriously insane! Two smaller zipties fit through that opening just fine and cost me pennies and work better than that cheap plastic clip.
Joshua Dworsky - 回复
Maybe i might have a older verison of the index because the larger clip piece on the top doesnt even clip in
Brent - 回复
scratch that you need to put the SMALLER side in last which is was this post doesnt say :)
Brent - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 61
过去 30 天: 195
总计 7,149
