跳转到主内容
Valve Index Headset Face Gasket Bezel Replacement
你所需要的
  1. Valve Index Headset Face Gasket Bezel Replacement, Adjust the eye tube relief: 步骤 1 中的图像 1,1
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Face Gasket Bezel Replacement, Remove the head strap clip: 步骤 2 中的图像 1,3 Valve Index Headset Face Gasket Bezel Replacement, Remove the head strap clip: 步骤 2 中的图像 2,3 Valve Index Headset Face Gasket Bezel Replacement, Remove the head strap clip: 步骤 2 中的图像 3,3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  3. Valve Index Headset Face Gasket Bezel Replacement, Remove the face gasket: 步骤 3 中的图像 1,2 Valve Index Headset Face Gasket Bezel Replacement, Remove the face gasket: 步骤 3 中的图像 2,2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  4. Valve Index Headset Face Gasket Bezel Replacement, Separate the cable from the head strap guide: 步骤 4 中的图像 1,2 Valve Index Headset Face Gasket Bezel Replacement, Separate the cable from the head strap guide: 步骤 4 中的图像 2,2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  5. Valve Index Headset Face Gasket Bezel Replacement, Disconnect the tether cable: 步骤 5 中的图像 1,2 Valve Index Headset Face Gasket Bezel Replacement, Disconnect the tether cable: 步骤 5 中的图像 2,2
    • Pull the tether cable straight back out of the headset.
  6. Valve Index Headset Face Gasket Bezel Replacement, Remove the face gasket bezel: 步骤 6 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  7. Valve Index Headset Face Gasket Bezel Replacement: 步骤 7 中的图像 1,2 Valve Index Headset Face Gasket Bezel Replacement: 步骤 7 中的图像 2,2
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
  8. Valve Index Headset Face Gasket Bezel Replacement: 步骤 8 中的图像 1,3 Valve Index Headset Face Gasket Bezel Replacement: 步骤 8 中的图像 2,3 Valve Index Headset Face Gasket Bezel Replacement: 步骤 8 中的图像 3,3
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
于02/25/19注册
73,693 声望
创作了288篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 83
总计 1,899
