简介
Follow this guide to remove the eye tube gasket for repairs or replacement on the Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
你所需要的
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Use your hand to gently pull the face gasket straight off of the headset.
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
另外一个人完成了本指南。
