跳转到主内容
VTechCS6719-16 Speaker Replacement
你所需要的
  1. VTechCS6719-16 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the sliding cover on the back of the phone case.
  2. VTechCS6719-16 Speaker Replacement: 步骤 2 中的图像 1,1
    • Now remove the battery by lifting it and removing the two pin cable.
  3. VTechCS6719-16 Speaker Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two 10mm screws on the back of the phone base.
  4. VTechCS6719-16 Speaker Replacement: 步骤 4 中的图像 1,1
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
  5. VTechCS6719-16 Speaker Replacement: 步骤 5 中的图像 1,1
    • The front case should now be freed.
    • Put the front case aside for later.
  6. VTechCS6719-16 Speaker Replacement: 步骤 6 中的图像 1,1
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
  7. VTechCS6719-16 Speaker Replacement: 步骤 7 中的图像 1,1
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
  8. VTechCS6719-16 Speaker Replacement: 步骤 8 中的图像 1,1
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
结论
Charles montes
于10/20/16注册
513 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 300
