跳转到主内容
VTech VM3254 Monitor Speaker Replacement
你所需要的
  1. VTech VM3254 Monitor Speaker Replacement, Battery: 步骤 1 中的图像 1,2 VTech VM3254 Monitor Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Speaker Replacement: 步骤 2 中的图像 1,3 VTech VM3254 Monitor Speaker Replacement: 步骤 2 中的图像 2,3 VTech VM3254 Monitor Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Speaker Replacement: 步骤 3 中的图像 1,2 VTech VM3254 Monitor Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Speaker Replacement: 步骤 4 中的图像 1,3 VTech VM3254 Monitor Speaker Replacement: 步骤 4 中的图像 2,3 VTech VM3254 Monitor Speaker Replacement: 步骤 4 中的图像 3,3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: 步骤 5 中的图像 1,2 VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: 步骤 5 中的图像 2,2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Speaker Replacement: 步骤 6 中的图像 1,1
    • Desolder the wire connecting the speaker to the board.
结论
Travis Gunter
于02/14/23注册
135 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 504
