跳转到主内容
VTech Spin and Learn Color Flashlight Speaker Replacement
你所需要的
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 步骤 1 中的图像 1,2 VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 步骤 1 中的图像 2,2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 步骤 2 中的图像 1,3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 步骤 2 中的图像 2,3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 步骤 2 中的图像 3,3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
结论
Nathaniel Troyer
于08/27/15注册
441 声望
创作了4篇指南
团队
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G6
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 460
