当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a plastic opening tool to pry the batteries out of their holding.
If replacing your batteries with new ones, be careful to insert them as indicated on the device.
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
The speaker should be located at the bottom-right side of the back cover from your perspective.
Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
Be careful not to disturb the wires while removing the screws.
Remove the speaker from its holding and place it to the side of the device.
Desolder the brown wires from the speaker connections.
Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
