跳转到主内容
VTech Little Apps Tablet Speaker Replacement
你所需要的
  1. VTech Little Apps Tablet Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
  2. VTech Little Apps Tablet Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
  3. VTech Little Apps Tablet Speaker Replacement, Back Cover: 步骤 3 中的图像 1,2 VTech Little Apps Tablet Speaker Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  4. VTech Little Apps Tablet Speaker Replacement: 步骤 4 中的图像 1,2 VTech Little Apps Tablet Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
  5. VTech Little Apps Tablet Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 VTech Little Apps Tablet Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • The speaker should be located at the bottom-right side of the back cover from your perspective.
    • Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
    • Be careful not to disturb the wires while removing the screws.
  6. VTech Little Apps Tablet Speaker Replacement: 步骤 6 中的图像 1,2 VTech Little Apps Tablet Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the speaker from its holding and place it to the side of the device.
    • Desolder the brown wires from the speaker connections.
    • Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
结论
Johnnie Cairns
于02/10/16注册
522 声望
创作了4篇指南
团队
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 1,280
