跳转到主内容
VTech Little Apps Tablet Battery Internal Wiring Replacement
你所需要的
  1. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
  2. VTech Little Apps Tablet Battery Internal Wiring Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
  3. VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 步骤 3 中的图像 1,2 VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  4. VTech Little Apps Tablet Battery Internal Wiring Replacement: 步骤 4 中的图像 1,2 VTech Little Apps Tablet Battery Internal Wiring Replacement: 步骤 4 中的图像 2,2
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
  5. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery Internal Wiring: 步骤 5 中的图像 1,1
    • Visually inspect the wires connecting the motherboard to the batteries, looking for damage.
    • Possible damage includes: lead disconnections, wire fraying, and complete wire disconnections.
  6. VTech Little Apps Tablet Battery Internal Wiring Replacement: 步骤 6 中的图像 1,1
    • Desolder the internal wire leads connected to the batteries, making sure to remove the positive (red) wire first, and the negative (black) wire second.
    • For assistance with soldering, see this Guide.
  7. VTech Little Apps Tablet Battery Internal Wiring Replacement: 步骤 7 中的图像 1,1
    • Next desolder the same black and red internal wire leads connected to the motherboard.
    • The order does not matter for this step.
结论
另外一个人完成了本指南。
Johnnie Cairns
于02/10/16注册
522 声望
创作了4篇指南
团队
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,385
