跳转到主内容
VTech Learning Tunes Karaoke Volume Switch Replacement
你所需要的
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 2 中的图像 1,2 VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 4 中的图像 1,2 VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 4 中的图像 2,2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 5 中的图像 1,2 VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 6 中的图像 1,1
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: 步骤 7 中的图像 1,1
结论
团队
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 254
