跳转到主内容
VTech CS6719-2 Speaker Replacement
你所需要的
  1. VTech CS6719-2 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 VTech CS6719-2 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: 步骤 2 中的图像 1,1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: 步骤 5 中的图像 1,2 VTech CS6719-2 Speaker Replacement, Circuit Board: 步骤 5 中的图像 2,2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: 步骤 7 中的图像 1,2 VTech CS6719-2 Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: 步骤 10 中的图像 1,1
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: 步骤 11 中的图像 1,1
    • Refer to How To Solder and Desolder Connections 如何焊接和拆焊
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very ho
结论
Benjamin Field
于02/08/16注册
270 声望
创作了2篇指南
团队
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G4
4 名成员
创作了16篇指南
2指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 1,046
