跳转到主内容
VTech Baby's Learning Laptop LEDs Replacement
你所需要的
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop LEDs Replacement: 步骤 2 中的图像 1,1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop LEDs Replacement: 步骤 3 中的图像 1,2 VTech Baby's Learning Laptop LEDs Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
  4. VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 1,3 VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 2,3 VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 3,3
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
  5. VTech Baby's Learning Laptop LEDs Replacement: 步骤 5 中的图像 1,1
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
  6. VTech Baby's Learning Laptop LEDs Replacement: 步骤 6 中的图像 1,1
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
结论
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 88
总计 1,333
